Hey everyone!  I've got a Stihl BG 86 blower that I just purchased and runs like crap.  Going through all the things it could be, I've settled on the ignition module and flywheel, but my problem is with the CORRECT SPECIFICATION for the gap.
The Stihl software that you folks were kind enough to pass along shows the attached pages in the Workshop Manual, which show the following:
a) from the BG 86 Specs in the Workshop Manual: gap = .15-.30mm
b) from the BG 86 Testing and Setting Data also in the Stihl software = .25mm
c) tool needed from Workshop Manual = 1127 890 6400
d) tool ordered and it's a .35mm setting gauge???
So............., my dilemma is this: What is the correct gap for the Stihl BG 86 blower? One part of the manual says it's .15-.30, another says it's .25mm (which is between .15 and .30), then the tool that's supposed to set this correctly is .35mm.
I set the gap with two .25mm brass feeler gauges on another BG 86 and it runs great. I've even swapped the module over to the older blower to see if the module was at fault, but the older blower an fine. I really think the ignition gap was out of spec on this poor-running blower, though I didn't check it to begin with... :-(
For what it's worth, I've pulled the ignition module and carb off of the poor-running machine and put them on my older BG 86 that runs great, and it still runs fine with the parts off the one that doesn't run well. I'm waiting on gaskets, tank fuel line, and a fuel filter to get the poor-running blower back together to start into the module gap issue, but this specification variance confuses me.
![IMG_0690[1].JPG IMG_0690[1].JPG](https://www.lawnmowerforum.com/data/attachments/43/43330-ddc1ad60a101b03ba58ae90ec481371e.jpg)
