UrbanSniper
- Sep 12, 2020
- Threads
- 2
- 7
Model 917.275972
So, I'd just replaced the ground drive belt last week (with the one from Sears, confirmed part numbers were right), no issues cutting last week. Got about 3/4 of the way through the cut this week, and as I started up a hill that I've been up hundreds of times, I get about halfway up and just suddenly the drive disengaged and I take off rolling backwards (thus providing impetus for me to move up the work on fixing the brake...). There was no warning before this, the blades never cut out, the engine continued running normally. Once stopped, letting off the brake pedal resulted in no movement at all, just like when the old belt had finally given up the ghost and slipped loose. I toggle the shifter, though, and the mower takes off just like normal, and I finished the rest of the cut without incident, even went on up the same hill again without trouble.
Any ideas what might've caused this? Did I just have the belt slip, or should I be looking at something else that's possibly worn out or damaged?
