davidharvey228
Hello all, I am working with a Husqvarna GT52XLS with Kawasaki FR730V 24 horsepower motor (motor has date of manufacture 08/16 labeled on it) and 118 hours on the meter. The issue I am running into is that after mowing for an hour the machine acts like it is about to run out of gas and shut off. However, if I turn off the mower deck and move the throttle down and back up a time or two the engine picks back up to running as normal. I can then re-engage the mower deck and cut for a few minutes before it repeats this same behavior. I have replaced the in-line fuel filter, the fuel pump, and the air filter. I have also blown out all the fuel lines to ensure they are clear. The only work around I have is letting the mower sit for extended time/overnight before running again but with keeping up 11 acres, this is not a great situation.
Many thanks in advance for any thoughts/comments/suggestions!
