error code b-in now
kellyhodge9905
brand new mower giving error code b-in now on a bad boy zt avenger
Are you sure it isn't 6-1 n now as in this thread from 2018
kellyhodge9905
Yes it is that code I was just reading it wrong
geelee
6-1 is the end code or some say the all clear.It will always read that. there is nothing wrong
kellyhodge9905
What are you meaning the end code I can't get my hrs to show because of this error that's all it shows
Richie F
If you can clear the code see if it comes back.
Richie F
I would disconnect the negative cable at the battery.
Don't know anything about this machine, but is has an ECM with memory, that I can tell.
In cars of today you can clear memory codes by doing the same thing.
Try it and see what happens.
kellyhodge9905
Thanks I will do that when I get home
