MowerMike
 - Sep 5, 2012
- Threads
 - 85
 - 964
One more thing to try, probably hopeless, but put some current into each cell with a charger that outputs around 4 volts for a couple minutes each. Then try your regular charger, if it sees some voltage on the pack it may actually recharge the pack.
It’s 10 cells in a 20 volt battery, so wouldn’t it be 2 volts. Perhaps you didn’t see my edited post. Anyway, I’m trying to get the eBay seller to accept a return.
