Last fall I added a OEM chute blocker to my Gravely Hd Zt 60, along with Oregon mulching blades. The idea was to go after the leaves in the yard. But with the blocker, seems like all I did was blow the leaves away from the mower before I could mulch 'em up. I suppose because the discharge chute was blocked. Ended up taking it off and making multiple passes. Now I'm wondering if I didn't fully commit to the project and need to go all in and get the complete kit which will include the baffles. Hate to drop another ~ $180 just to have the same problem, leaves being blown AWAY from the deck. Your thoughts?
The more and more that I see posts like this it makes me wonder who thought it would be a good idea to market Gators (and alike) as mulching blades!!!! These types of blades are nothing more than serrated sail, high lift blades. The perception is, and most people believe, that Gators are "mulching" the grass when all they do is (sometimes) cut grass and (most often) leaves into finer pieces, BUT they are only intended to discharge, hence the taller sail. "Mulching" blades, which are wavy and have a very low lift, are designed to recirculate the grass clippings underneath the deck and to also push those clippings back down into the turf. The best mulching of any material will have to be a combination of: a clean deck, sharp mulching (wavy) blades, deck baffles, dry grass, paced mowing speed and only cutting off 1/3 of the clippings. A deep deck and lots of engine power help but aren't necessary if the other conditions are present, it just helps.
Most people are disappointed in mulching kits as they are truly exceptional on well manicures, frequently mowed lawns and truly terrible on anything else.
Try different combinations of blades, baffles and chute blocks to suit your needs.  A little trial and error will help in finding what works best for the lawns you mow.
