benga
Hi, picked up this mower which I believe is a TB 120 for $40 so figured it'd be a good learning experience for me on small engines. I'm a little stumped though on why my mower is still pulsing after doing a carb clean and replacing the long jet, not the one that screws in place.
It pulses immediately after turning on. It had some bad fuel which I replaced and the oil. I disassembled and cleaned the carb completely. I just can't figure out what is causing it to bounce so much.You can see the governor pulsing in the video.
