xray man
On the backside of fuel tank there's a dipped out area where the fuel line comes down from the top of the tank. The fuel tank is two parts. Do the fuel tanks leak very often where they're joined? I saw that the area where the fuel line goes through the dipped out place is where the leak is. (see picture) But I can't tell if it's the line or the tank. I did find what might be a pinhole in the fuel line. I'm going to replace part of the fuel line. I sincerely hope that is where the leak is cause it looks like removing the tank will be a pita. I was just checking to see if anybody's run across the same problem before. Thanks
