2015 titan mx4800
bman6965
my titan has tore up 6 deck belts, i have replaced pulleys, idler spring still no help.
Scrubcadet10
Moderator
Staff member
Do you have the correct belt, 133-1166
bman6965
yes i replaced the oem belt with an oem belt in fact the original belt became frayed within a year. i have since replaced it 5 times along with pulley and spring.
Scrubcadet10
Moderator
Staff member
Which pulleys have you replaced? Just idlers, or idlers and spindle pulleys... Have you checked the PTO pulley for defects?
bman6965
i have replaced both, the belt seems to vibrate a lot i have replaced the idler spring 4 times
bman6965
what defects would i be looking for on the pto pulley
Scrubcadet10
Moderator
Staff member
I would check for any burs/sharp points where the belt rides, Does it have manual engagement or does it use an electric PTO clutch?
A frayed belt is generally caused by it running against some thing that it is not supposed to.
Usually it is because the belt is on the wrong side of a belt guide.
Other things are worn deck mounts allowing too much movement in the deck.
Finally are you 100% sure the belt is routed correctly ?
Even techs can put them on wrong .
A deck belt should go several hundred hours standing on its head .
