Hey, changed the oil on my mower today, and when I tipped it back down after draining the oil and refilling noticed that the breather/vacuum tube was disconnected from the carbs rubber grommet and doesn’t seem to want to connect. It doesn’t appear that if I unbolt the fuel tank and back it off I’ll be able to re-attach it but maybe? Figured I would check about this before I do anything. Haven’t encountered this before. Is it normal for these two to become disconnected due to vibrations or something? Everything look normal?
