That is a lot worst than I suspected but I know when magnets turn loose they do a lot damage. Pull the stator and see if the mounting posts are still intact. If still intact then it is a new stator and flywheel time. IF the posts are broken then it is probably time to replace the engine due cost involved vs replacement.
