2018 3038 wont read neutral.
BuddyAucoin
was running my tractor and stopped it to get a water. when I got back on the dash wont read that it is in neutral. I can get it started
most likely a blown globe if everything else is working properly.
Hammermechanicman
If it is a 3038 compact tractor i think the neutral switch screws into the side if the transmission. Looks loke an oil pressure switch but is a mechanical switch.
