Front Drive Wheels Keep Wearing Out!
mckdt
I have an HU 700F walk behind front self-propelled push mower. I am replacing my front drive wheels every year. The metal sprocket is grinding the plastic teeth off of the inside of the wheels. Last year I replaced the wheels and the metal sprockets. Did not last one season. Why is this continuing to happen?
This is how I fixed mine years ago and it still works. The wheel height adjuster is putting too much horizontal pressure on the wheel mounting plates causing a toe-in condition. Read comment with each photo Hope this helps. https://www.flickr.com/photos/24045457@N02/sets/72157668326021968/with/27762628118/
I have seen where the teeth themselves on the wheel are totally chewed to a nub the slipping, it must be the teeth. I would suggest get a file or dremel tool and round off the metal teeth. They must be shaving the plastic teeth.
I have seen sears mowers with the same setup from the 80's and the teeth are fine so it *can* last alot longer.
