2 blade 42 inch deck. Fabricated. Brand new zero turn with mulch kit. Cut pretty good when side discharging. Installed mulch kit, this is the result. Very disappointed.Lots of things can cause that : Dull blades, wrong blades, blades on upside down (yes, I have actually seen blades on upside down), worn out blades, deck not pitched right, deck filled up with debris (grass build-up), blades not spinning fast enough, mowing too fast. Is this a 2 or 3 blade deck?
Yep, you found your own problem....mulch kit ! We don't recommend mulch kits on mowers we sell but, if you must have one, don't mow tall grass and keep it mowed often to eliminate tall grass!2 blade 42 inch deck. Fabricated. Brand new zero turn with mulch kit. Cut pretty good when side discharging. Installed mulch kit, this is the result. Very disappointed.
I don't want to be the who tells you this but, as you are finding out, buying a mower online or from a box store IS NEVER A GOOD IDEA, you might be forced to keep the mower, if so, you might have to take the mulch kit off........good luck to you !Thanks for responding. I'm guessing after this post nobody will have the balls to respond although I do need some encouragement and or advise.
I purchased a new Ariens Edge 42" upon the recommendations of a fairly well know YouTuber. I had to buy the mower online as everyone else locally were sold out. After I installed the mulch kit and was having cut problems I looked and found reviews that were disparaging regarding it's the mulch kit's performance. I had previously owned a Toro Timecutter that mulched perfect so I wasn't anticipating any problems. I had to purchase this mower online as nobody near me had any in stock. I contacted the Online vendor about this cutting problem and they said they couldn't help me because I put gas in it and ran it.
I contacted a person who has connections with Ariens and he told me Ariens knows of the mulching problems but there is currently no fix. I also discovered on YouTube that for years people were having problems with Ariens mulch kits.
I have called my Credit Card company and am in the process disputing the charge for this mower as I am totally unhappy with the mulch cut.
I find the cut totally unacceptable.
I contacted Ariens and they want me to take it to an authorized Dealer which I can do but I have checked everything except the RPMs of the mower.
I simply do not want this mower as the mulch results are unexceptable and I mulch 100% of the time.
What are your thought people?
I forgot to add I've been mulching for 40 years and know all the intricaciesof the process.
Thanks Mower King. Yeah this is the first time I have purchased a mower online. I have always bought locally. I sold my Timecutter and needed a new mower, thought I would try an Ariens. I was shocked when I started to cut with the mulch kit.I don't want to be the who tells you this but, as you are finding out, buying a mower online or from a box store IS NEVER A GOOD IDEA, you might be forced to keep the mower, if so, you might have to take the mulch kit off........good luck to you !
Thanks for the response! I tried taking the mulching blades off and replaced them with the original Ariens high lift blades and it did do a better job just not acceptable which is the problem. Ariens sells a mower and mulching kit that cuts the grass horribly. I am going to demand my money back with the C/C company. Ariens knows of the problem and does nothing about it and keeps selling this under performing product to unsuspecting purchasers. It's not right and I'm going to fight it.I'd try taking off those mulching blades & go back to some high-lift Oregon straight blades. Mower a little slower, more often.
