Husqvarna online schematics and the vendor parts lists have not been friendly. The dashboard locker switch does not have a Husq part number on it and pursuit has been tedious. Turns out the switch is a ":Carling" (CT) part, but without a full part number of 14 digits. Searching only the first 4, namely VDD1 only opens up a candy story of possibilities with a risk The switch is a DPDT controlling the locking diff "motor" (schematic symbol), which is really a linear actuator, fancy name for a 12v motor turning an Acme screw with ram attached to the Husqy diff lock lever. Husqy was able to put its part number on the actuator, 584393401 (sorry pic not show it). Online price $227 to $240. The switch is basically a 6 pin with one unused cavity and #7 dedicated to the LED. The 6 pins supply forward and reverse voltage and ground (lock and unlock).
Attached are pics of mating harness, actuator, and an info sheet as requested by Carling. I stumbled on a Carling switch with full part number ID digits: VDD1SWOB-AZS00-0. Anyone curious can find a PDF data sheet online. That part is available at electronics stores $15. Versions of the switch exist without LED and various colors.
Well I am being denied attachments as "too large." Way back I think I would trim pics via paint function. Now?
No response from Carling. Further ref to their data sheet says "VDD1 pn is enough to buy and work. May or not have LED. On order. Boat sites take this sw , put their pn on it and charge $35. Should pay about $12 plus ship/tx.
