seattlepioneer
 - Jun 20, 2020
- Threads
 - 10
 - 93
12f8022021e1
I notice that the Briggs operating manual specifies that the "combustion chamber" m should be cleaned every 100-300 hours of operation.
I'm supposing that would involve opening the head and inspecting and cleaning the head of the piston and valves as needed ---or something else?
What kinds of things might you expect to find on a new or old mower when doing this as ordinary maintenance? Is that something often neglected?
I've seen a You Tube video of an engine with no compression due to a cylinder scored with crusted oil deposits. The mower was junk due to the damage. Perhaps that would have been avoided if that kind of routine maintenance has caught the oil accumulation earlier?
