Problem starting B&S engine on a craftsman mower
Vintshave
I have the mower shown below. It’s been sitting for awhile. The throttle control cable is broken and the cable that attaches to the front drive wheel control is slack. I keep pulling the rope with gas in the tank and it won’t start. If I spray starter fluid into the air intake it starts and then quickly shuts off. Any advice would be welcome.
EC649618-558D-4128-B4D1-E3B75D70CE85.jpegC7E1C57E-C617-4603-AEE8-A28140398B67.jpeg376DB996-28AF-4FB5-82A0-BFE058BD359E.jpeg2213DCAF-433C-4959-BDF2-9E8279842971.jpeg
Depends upon how much of a problem it is .
A sticky exhaust in particular will run if you shoot starting fluid down the carb
An inlet valve stuck partially open may also run a few seconds .
You can start with the carb then go to the valves next if a carb clean does not do the trick.
I'll try that. Also, can you tell me what cable I would need to replace the twist tie I'm currently using for the throttle? I'm also curious why there is slack in the cable that controls the power drive. Could the fact that I can't pull back on the bar (since the cable is not attached to it) be triggering some kind of auto engine cutoff?
OK, I replaced the following parts:
Drive cable
Throttle Cable
Filter
Springs
Carburetor
Spark plug
After I replaced the carb (which was very corroded), the mower started on one pull and I was able to mow for about a minute before it cut out. I couldn't restart it. Damn.
Since the mower was sitting for some time, I replaced the spark plug. Started right up. Ran for about 30 seconds and then cut out. Couldn't restart it. Damn again.
In both instances, I shot starter fluid into the carb after it died. Nothing at all. Didn't even restart for a few seconds.
At this point, I'm at a loss - mentally and financially. I can't imagine what else it could be. It ran - albeit for a short time. What should I be checking next?
Drive cable
Throttle Cable
Filter
Springs
Carburetor
Spark plug
I'm currently experiencing the problem you describe with a similar engine and the same carburetor.
I replaced the carburetor with a $14 Chinese knockoff, and the same problem continues. If I prime the engine, it starts fine but then quits running after a few seconds.
Sounds like no fuel to me.
With a new carburetor on it, my next step will be to replace the fuel line, which has a fuel filter in it which could be plugged up or otherwise defective. In any case, it's an old mower and replacing the fuel line is worth while maintenance in any case.
If that doesn't work, I'm going to suppose that the new carb is no good. I bought two $14 carbs, so I have another one to try out.
Those are my best ideas so far.
Oil, fuel, air filter and such seem OK, and the mower starts fine when primed. So my operating assumption is that the engine is not getting fuel.
check the valves and test the spark plug is working since a plug can just go bad like that sometimes
if it does start with starter fluid 99% of time you have no spark
also i think the fresh gas could have loosened up varnish in the gas tank from sitting all that time and that may have sludge gummed up your new carburetor in the short time it ran, but it should still have started with the starter fluid
Thanks for your comments.
The fuel line had a filter in it, but I've supposed that a partially plugged filter might impair fuel flow, and in any case the fuel line was old. so I replaced it.
I then inspected the fuel tank, which I found to be contaminated with crud. I removed the fuel tank and repeatedly added gas to the tank and shook the fuel around to entrain the crud and empty it out until the fuel ran clear.
I tried to clean the new carb, which was a $14 knock off. When I took the fuel bowl off, I noted a couple of areas which were ALREADY corroded through the plating on the bowl. Furthermore, the gasket to seal the bowl to the carb body wouldn't fit once it was removed, having stretched and being notably too large to get it back to fit.
At least now I'm satisfied that I have good fuel to the end of the fuel line.
I guess I'm going to buy a B&S carb and try again.
I've assumed that since the mower will start when it has fuel dumped into the carb that the spark plug and spark must be OK. Is that wrong?
It starts reliably when fuel is dumped into the carb, but after 15 seconds or so that fuel is consumed and the engine stops. Even if I manually open the throttle on the carb, the engine still quits. I've presumed that has been happening because of no fuel.
B&S
12F 802-2021-E1
Code 99062966
Briggs and Stratton carburetor part number 799868
