- Feb 19, 2020
- Threads
- 114
- 12,312
Probably explains why I haven't seen the O2 sensors as every Kohler that I have worked on are non EFI systems. I have yet to see Briggs system even though I brought the Briggs tester setup but probably end up having to buy a newer system when one does show up.Kohler has been using O2 sensors for close to 20 years starting with the CH26. the newer ones are 4 wire with heater circuit closed loop systems. I don't see a standardization of the systems right now. The best is a generac code reader for Kohler, Briggs, MTD, for retrieving the codes. But as of right now Kohler is moving to their 3rd version of the software with a new connector plug to work with the new electronic governor systems. And that system will not work with the CAN BUS system of the mower that it is one that required the mower manufacturer software. So there are two diagnostic plugs on some mowers. One for the engine and one for the mower.
All fun to deal with (not) Just unexpected additional expenses and equipment to keep with just keep working these machines. I am considering retiring when I get to 65 in four years and let the younger bunch of part replacers pull their hair out.
