CraigslistGuy
Hey Guys,
I got a Craftsman LT1000 midel number 917.271643.
It sat for about 3 years before I decided to fix it and get it running. I replaced the engine and it runs fine.
The only issue I'm having is when I put the mower in gear, it makes grinding noise. Its not that noticible and mower moves forward / backward as it use to before. However, recently I tried to use a dethatcher with a block on it, and the griding noise got extremely loud and the mower barely would move foreard. Removing the dethatcher, it again moves normal but the grinding sound is still there (just not as loud).
Checked the transmission oil, and it was ful, but still changed it with 20w50. Noise is still there.
I pulled the transmission lever where it stops the transmission from moving and put it in gear and looked under the mower. All the pulleys seem fine and there was no noise. So it only comes when mower moves forward / reverse.
Anyone got any idea what might be the issue or sugguestions as to what else I should check for?
Thanks
Thanks
