thx but i miswrote only 10psi compression thxMost engines now have compression releases which reduce compression at cranking rpms. Beside that, 110 psi is enough for an engine to start and run.
If it's still under warranty, let them fix it.
interesting..... i squirt fuel in carb right after i check the oil on all non starters for pops but the only firing pops i heard on this one r like backfires in the exhaust as if the cam tiring is way off or the exhaust valve is sticking open.....i removed the rocker arms and both valves bounce right back as normal, valve lash within specCompression is about meaningless on newer engines. I performed a leakdown test on a generator several months back that had less than 5% bypass but only showed 5 psi on the gauge. Engine ran fine after cleaning the exhaust screen. I would be looking into fuel quality and try putting a small amount of FRESH fuel into the intake and see if it pops off or not.
