Grousemansav
Ok so my Craftsman lawn mower was working fine until this morning. It is a 2002 mower with a 6 ½ HP Briggs & Stratton Model123K02-02260E1 engine. I used my spark tester hooked up to the spark plug and there was no spark. So then I hooked the tester directly to the block and there was spark. I changed plugs but still the same results. So I’m thinking it must be a really weak spark. I cleaned the magneto and reset the flywheel gap to one business card thick. Still the same results.
Then I looked at the kill switch and everything looked OK. I unhooked the kill switch wire and put my VOM between the wire and the block and there was 0 ohms resistance which says to me that the kill switch wire is shorted to ground. I checked the condition of the wire back to the magneto and it is good.
As far as I can figure, that wire from the magneto should not be shorted to ground until the kill switch closes for safety. That being the case I figure it must be internally shorted in the magneto and I need to replace the magneto.
I am relatively new to this so would really appreciate any input from experienced repairman.
Stay safe, Grouseman
