Hammermechanicman
Have you checked that the air pressure sensor is changing voltage when the engine cranks? Sounds like you have an ecu input problem. If you have checked the injectors and swapped the ecu that pretty much leaves an input to the ecu not working. Check the wiring connections to the sensors.
