Lawn Machine Mower need model number & Deck Problem
afees98
Hello, I am looking for a bit of help to identify a Lawn Machine by MDT. I am having an issue with the deck that, when am cutting an any kind of angle (like a hill), the deck bogs down, but the engines doesnt bog down. I haven't found anything on this issue yet on the internet.
By the pictures below, you can see that I did repaint from its original Dark Green color in order to clean up rust on the back end. I have already check all over the mower for a plate for the model number but it doesn't have one anyone. Didnt have one when I got it.
If anyone can idenify the mower with the pictures listed below, that would be great.
https://prnt.sc/sdvetb
https://prnt.sc/sdvf6r
https://prnt.sc/sdvfjb
https://prnt.sc/sdvfst
https://prnt.sc/sdvg1l
If you can't, I would greatly take help with the mower deck problem.
Thanks in advance! :)
13AK695H352 may be a good possible. Or 13AQ695H352 is another one Assuming 46 inch deck and hydrostat transmission.
It is a 42in deck... Forgot to put that in the post.
OK try 13AS695G352 as a possible. there are similar model of the 1997 model year but most would just be a cosmetic change depending on the last three digits of the model number depending who it was made for. I am assuming this was sold by Walmart, but others sold a similar model also.
Ok. Am not sure where it was sold at since I got for free from family member, and they got it from there neighbor
To quote our most embarrasing pollie down here. "please explainee"
Bogs down ?
Like I stated in my post, The deck bogs down when on a slight hill causing the mower to be at a angle. The engine isnt bogging, its just the deck.
Are you sure it isn't a 46 inch deck The pictures look more like a 46 than a 42
I will have to check tomorrow, its a 3 blade deck.
Raise the seat up and look on the bottom of it for a tag.
I have already looked everywhere on that mower for a tag, it is not there (Or I wouldnt be asking lmao).
