Mower does not go into gears at all
rigoletto
People,
MTD rider mower, from 1998, Starts fine, wont go into either forward or reverse. Stick shifter seems to move in the right directions, but transmission will not engage. Will post my model # in minutes if that will help.....
Fish
Can you get it into gear when the engine is off?
rigoletto
Yes, i tried that. Will shift rear/forward. And the mower is in gear (wont move at all). Si then I figured let me try starting it again and see- same thing- when engine runs (idle) shift wont budge either way. Thanks!
Fish
Can you push it when in neutral?
Your parking brake may just be stuck.
Fish
Can you read the model number off of the tag under/behind the seat?
If so, post it here.
Fish
If this looks like yours, reach up there and wiggle #40 in the pic.
rigoletto
Sorry for delay, Fish, was at work all day. But wow, so much good info you sent! I will follow up on your ideas as soon as it stops pouring down rain. Could be another day/2. Then I will let you know what I found out!!
Fish
If it looks like this one, wiggle #56
Fish
If it is a stuck brake, you will hear a click when it breaks free.
