PersonalJester
- May 26, 2015
- 7
Hi there
Am trying to start my Alko mower without any luck.
The place where I bought it are closed due to pandemic, so cannot contact them for advice.
It uses a B&S EBSXS.7242VA. It turns over but no sign at all of firing.
I have tested/tried:
Fuel tank has fuel!
Plugs are clean
Plugs spark when turned over
Good supply of fuel to pipe into carb
Air filter new
I suspect no fuel through carb. Is there a way I can squirt some fuel directly into carb\engine to prove it?
Is there a float chamber on this engine? Maybe the float needle valve stuck?
Any help appreciated.
Fuel tank has fuel!
Plugs are clean
Air filter new
