BTW, can someone tell me where I put the coil to this mower? I had everything together, In one container. Except the coil.
Do these coils have legs? HA HA HA HA HA
On that drill the chuck is probably a tapered fit. It does take quite pressure to get it seated properly. Now of course I got the floor model (not to be confused with the store's demo one) and haven't had any problem; although, I run it at the slowest speed.
And yes some of their stuff is nothing but junk. Like the tap and die set I brought that was poorly made and the puller set that the forcing screw was off axis, THe first puller set was good until I broke it try to pull off a hub that had torqued to 300 ft-lbs.
It gets worse believe me. CRS is a terrible thing!BTW, can someone tell me where I put the coil to this mower? I had everything together, In one container. Except the coil.
Hey I resemble that. I can lose my glasses right in front of me. Then have to go get the other pair to find the ones I laid down.It gets worse believe me. CRS is a terrible thing!
The idle circuit for the carb is under that triangle shaped piece that your boss said not to remove. It should be removed to clean the idle passages.. That pump on the side is the accelerator pump like the old auto carbs from years ago. The white smoke is most likely oil. No unusual for the Command to smoke slightly on start up due to oil seeping past the rings.
