- May 6, 2010
- 12,063
I was assuming that after the carb repair you installed the air cleaner base plate to the carb. If it is doing the flooding without the air cleaner base plate attached to the carb, then I would look at either the gasket between the two halves of the carb, or the needle valve isn't sealing. also make sure that the float isn't full of gas.
