crobertson521
Replaced my carb on my husqvarna YTH22v46 having an issue with the linkage the throttle arm is pulling at the carb keeping it open regardless of throttle position. Any help much appreciated I’m at a wits end, The choke closes fine but its like the throttle arm just doesn't push up enough to close the throttle on the carb. Maybe I got the linkage wrong? I can provide more pictures if it helps.
