I have the following carburetor WYL. It is from a Troy-Bilt backpack blower. I can not find where the carburetor adjustments are for high and low. It seems the closes is the adjuster screw for idle. I rebuilt the carb and it idles but when I press the gas it cuts off. I need to adjust the carb to get it to not fall on its a$$.
Thanks
Thanks
