Honda GX620 clacking noise
surely there is enough piston head clearance for a butterfly screw? I’d expect it to have pinged out the exhaust valve, could be stuck under a valve.
The more I think about it the more I think decomp off the cam, but yes should probably bite the bullet and pull the head or side cover.
Heads have not been removed. Uncanny thinking mate. After being left in the rain the carb was seized, I ordered a new one and when I pulled the old one the butterfly fell out on the bench. Could well be a bit of metal mashed to the top of a cylinder.
What’s easier to pull, head or side cover?
They're both about the same....
Sidecover probably
Its happened on a few inteks. Taryl fixes all mentioned that on youtube. It hammered the piston and pinched the rings so it was smoking like a son of a gun.
The landlords Kohler managed to swallow a screw from the carb butterfly.
It had been getting harder & harder to start for quite a long while
We were amazed when I shoved the bore-a-scope down the plug hole & saw the moonscape
Small piece of magnetic metal stuck to head
Could be a spark plug electrode but who knows
Anyone know what this is? Heavy for its size and magnetic
