Fish
- Aug 2, 2013
- 5,145
Looks like your engine has smartspark, I looked up your engine and it said that you did not, so I didn't suggest it.
That is very likely your problem
I don't believe that your mower had any other problems, I would clean up the valves, and put it back together and run it. Have the valve heads redone, as that was likely the only spot that you were losing any compression, but even that was minor.
From the cylinder pictures you can tell there is cylinder wear, and the pistons look like they would be able to tilt back and forth. Is there a ridge at the top of the cylinders that you can catch a fingernail on. The newer style thin rings tend to loose their sealing ability after very little wear. After you get the pistons out take one of the rings and slide it back down the cylinder and see how much gap there is.
