Broken belt blade Poulan pro 22HP
Freedom
The belt of my blade broke after one month use (aprox 15 hours use)
Possible causes:
*spindles
*deck level
* tall grass
spindles move ok
The grass was tall, almost 40 cm
deck level, I must check that
I DO NOT want to change the belt every month :)
any tips??
Thanks in advance!
F
Scrubcadet10
Moderator
Staff member
Kind of odd for belts to break. They usually stretch.
You may have just gotten a dud belt
Possible causes:
*spindles
*deck level
* tall grass
spindles move ok
any tips??
Thanks in advance!
F
There are lots of things that can cause a belt to break and various different ways it can brake .
We need some photos of the belt and in particular the spot where it broke.
