rickpaulos
100202 401056 6207230
Installing a new carb kit. There is a ~1" coil spring (govenor spring) that connects from the throttle cable to the regulator arm (bushing lever). The bracket has 2 holes in it. Which does the spring attach to? All the parts photos on the web don't show the spring connected, just hanging loose.
the motor in question:
I took before photos but this spring is buried below the tank and I don't recall which hole it goes in to. The long arm or the short arm?
is this correct?
Also any tips on getting the second carb bolt tight? it's nearly inaccessable. Sockets won't fit. I have two different brands of 3/8" combo wrenches and neither fits well. There just isn't enough room to turn the wrench even 1/6" of a turn and flipping the wrench doesn't fit. The carb is at an angle so a screw driver is out of the question even my tiny right angle ratchet flat blade.
is this correct?
