gregjo1948
- Nov 28, 2012
- Threads
- 76
- 364
Where can I get a reasonably priced valve seat cutter/grinder for a FH580V? Also, what are the diameters of the valves and the valve guides? thank you, gregjo1948
Where in PA. do you work? If you're close enough, I'd have you do my seats. gregjo1948look at neway valve seat cutter kits, its what I use at work.
https://www.mymowerparts.com/pdf/Ka...SAKI-SERVICE-REPAIR-MANUAL--99924-2078-01.pdf
Here's a service and Repair Manual. it also talks about valve seat cutting.
Neway do a small engine kit which is fairly standard kit for most mower shops.
Downside it is not cheap, because they are good.
SO unless you are a workshop take it to another workshop.
I charge $ 20 (AUD) per valve, takes about 5 minutes + clean up.
Bought mine 6 years ago and in reality it is yet to pay for itself.
OTOH you must have one to do side valve valve lash unless you always fit new valves.
Figured as much
Good gear is never cheap but unless you have a lot to do much better off poping down to the local mower repair shop.
Just a word to the wise thoug.
Take it to a mower REPAIR shop, the type that has 20 old refurbished mowers for sale out the front, not a glass front retail outlet.
