Jetblast
It's almost two years since I started this thread, so here's an update. The lovefest remains strong and everything I said is still true. It has performed flawlessly and is a pleasure to use, however I did have to make some mods to make it my dream machine.
1. It really needed the rear anti-scalp/striping rollers of the 700 and 900, because I was having scalping problems over my leach field. Solved.
2. I wanted the bigger front wheels that come on the 700 and 900 Pro Z S for better wet steering traction, so I added those. That required re-leveling the deck, but that's it. All associated parts, including the front forks, are the same. Honestly can't tell much difference with that mod, but it was cheap and easy and the bigger wheels look nice. I give this upgrade a five out of ten just for the fact that I can confidently run a couple of pounds less air pressure due to the larger tire bead area.
3. Because my yard is so bumpy, I thought the EVC elastomeric vibration control seat isolation of the 700s and 900s would help. This is not the vertical suspension in the seat itself, but the rubber pieces the seat is mounted to. They allow for a couple inches of lateral seat movement over bumpy areas, and holy cow that made a huge difference. It was not subtle. It was huge. This was the most expensive and difficult to install upgrade, and had as big of a payoff as the rear deck rollers.
After these three mods, I'm still under the cost of a 700 and have retained the relative fuel economy of my 850cc engine, which has more than enough power to handle my slopes and goes as fast as my yard allows. That said, if you have bumps and don't want to fiddle with buying parts and installing them, I'd start with eyes on the 700 and skip the 500. Even more so if you can use the extra speed of the costlier machines.
The steering wheel knob didn't last long. Turns out with a bit of practice I can whip the wheel around with the heel of my hand just as well, and the knob was otherwise getting in the way.
I live in SW Ohio where there are ponds, ditches, fences, and slopes everywhere, and a lot of rain. I'm surprised I'm not seeing Pro Z S mowers on more lawn company trailers. They live for this environment.
