pict1000
Try running a temporary wire 16 gauge or larger from the B+ terminal to the positive post of the battery and see what what voltage you get when testing the charge at the battery terminals.
Since cleaning the positive battery cable connections on both its ends didn't fix the problem, I'll be trying your B+ to battery bypass-wire test tomorrow morning. Once again, I'll be posting my results after that. BTW, my positive battery cable does have continuity -- FYI.
