My twenty year old 10 HP Briggs (205412-0120-E1) threw a rod and I’m in the process of rebuilding the motor with a new rod (694691) and rings. Problem is that the rod tightens onto the crank journal when the con rod bolts are tightened to 50% of spec (spec = 100 in*lb). Below are pics of the rod and journal when I rotate the rod dry with bolts tightened half of spec:
Prior to rebuild I sanded the crank journal using 1000 grit sandpaper and WD40. I don’t believe the failed crank left any aluminum on the journal and the crank surface looked perfect after sanding. I measured the crank diameter at 1.2500 inch using a calibrated Mitutoya caliper having a resolution of 0.0005". Using ID snap gages I measured the ID of the con rod at 1.2495 inch when tightened to spec. Obviously I have an interference condition.
I added two 0.006" paper shims under the ends on the con rod cap and got the rod to spin but that’s not a permanent fix.
Is my con rod out of specification or am I doing something wrong?
What radial clearance should I expect to see? For example, a 0.002" rod gap should yield a rod ID of 1.254".
