cub cadet rzt L
TERRYDOWN
This zero turn is about 3 years old- changed oil/ oil filter, air filter- fuel pump- My question is, why after mowing for maybe 10 minutes
the mower starts running erratically and acts like it wants to die- If I push the lever into "choke" for a second it quits. I get another
few minutes and it starts over- HELP :)
MowLife
The motor is starving for fuel. Check fuel filter and fuel tank for a blockage. If that all looks good then going into the carb would be my next suggestion.
TERRYDOWN
Will Try.... Ill keep you updated & Thank You!
Can be the tank vent or a plug of debris in the fuel outlet of the tank.
