Good Lord I gotta say...this forum and participants are not only fantastic, but very impressive and generous.  I want to thank each of you for taking your precious time to reply to my thread!  I'm not at the expert level that you guys are so please overlook that of me.  That said, I've done the following in addition to actions taken in my initial post:
1) Replaced Fuse Holder,
2) Replaced Battery Cables,
3) Replaced Battery (my fault, I broke a corroded terminal),
4) My second mower repair guy has not been able to fix this 20 amp  fuse blowing issue:
         1st Repairman: You need a new PTO Clutch, short in clutch, so purchased OEM Briggs and Stratton PTO Clutch for $250, same result.
          2nd Repairman:  All is well with blades cutting until about 10 minutes, then blows fuse.  Told me that my PTO clutch was hot to the touch so was the cause of blowing 20 amp fuse.  The real issue I see is...difficult to troulbleshoot since fuse does not blow or no issues at all, until afgter 10 minutes of cutting grass, then blades stop, and engine still runs,,,
I'm actually thinking that these 2 repairmen are 'shade tree' repairmen and do not know how to troubleshoot electrical grounds (ie troubleshooting like: if ignition switch is in one position, there is a short in 1 circuit or if ignition switch is in another position, its this circuit) and while I'm no expert either.  I hate to consider the cost of a new mower when I feel as if there might be a simple fix.....everything is fantastic while the fuse does not blow...engine runs fantastic!!  Thanks again you guys!  Y'all so gracious and generous with your time on my behalf!!  Thank you!!
