My Hustler Raptor stopped suddenly and wont start.
Thank you so much. As you can tell, I am not a lawn mower guru. But now I know what to get, and I should be mowing again shortly.
When you refit it move that ground wire right out of the way where it can not get snagged in the future.
Does not matter where it goes just so long as it is ground.
That part you need, to repair correctly, is Kawasaki part 26031-7041. Available from a Kawasaki engine dealer.
I have the SD54 but I think your 60 might use the same guard?
Mine was #119597 about $80.
I think it makes the mower look better too.
Probably should have been stock but this is a bottom of the line Hustler mower.
