- Nov 29, 2014
- 24,995
It sounds like a leaking head gasket, loose inlet guide or broken flywheel key .
However to be double sure take the plug out and poke a long screwdriver down the plug hole till it touches the top of the piston.
put a little pressure on the piston and with your other hand turn the engine over 2 full revolutions.
The piston should move smoothly from the top to the bottom of the stroke.
Now if the piston clicks or suddenly drops as the motion changed from in to out then the rod is gone.
The two valves you just adjusted should sit at identical heights when the rockers are not pressing on them.
If not then one of the valve guides has slipped.
These engines generally blow the head gasket between the bore & the pushrod tube but occasionally they go between the bore & one of the valves
