drsauerhoefer
 - Dec 11, 2018
- Threads
 - 1
 - 4
When my Poulan P3314 type 1 is sitting not running the bar oil leaks out all over.
Part #52 is the oil pump:
https://www.jackssmallengines.com/j...w-type-1/handle-chassis-bar-assembly-type-1-2
Besides the above, you can either replace the pump, fresh rubber, everything seats tight against each other, etc, OR try setting the machine on it's left side, so the pump is the highest and the oil tank is low(gravity isn't help the oil escape).
Attached photo is where oil is leaking out from![]()
