- Sep 24, 2017
- Threads
- 288
- 6,884
Model # HRX217 TDA
I got the carb put back on (New gaskets) after cleaning, but im not sure i have the throttle linkage on correctly, whenever i move the the throttle lever on the handle sometimes the (whatever the rod and spring hooks to on the carb is called) moves and sometimes it doesn't. Maybe these picture will clarify. I think the return spring may be sprung.. not sure:confused2::confused2: i can't run it because im waiting on gasket maker for the rocker cover (store didn't have any high heat stuff)
