StatesboroMike
- Aug 2, 2018
- 26
Mike out of curiosity I checked the ROP shop AND ALL of ebay, no replacement carb !! DUH !! BUT.. there is a used carb & manifold for $55.00 + shipping (about $16.00) = $70+ bucks if that interests you, BUT it ends Monday , might try to contact seller ASAP .. if you're interested.. your engine may be too new on the market for them to mfg those carbs. NEW carb = $ 165.00 and UP ..OUCH !!
SORRY if i dashed your hopes of a CHEAP carb.. MY BAD !!
here's some info ..
https://www.ebay.com/itm/Briggs-Str...675948?hash=item4d78a6c06c:g:fJ0AAOSw7pZbXSZz
https://www.jackssmallengines.com/j...-40n899/40n877-0004-g1/carburetor-fuel-filter
https://www.repairclinic.com/Shop-F...Briggs-Stratton-Small-Engine-Carburetor-Parts
https://www.partswarehouse.com/40N877-0004-G1-Briggs-and-Stratton-Engine-s/239559.htm#
Your carb is SIMILAR to the NIKKI 1 Bbl. used on the SINGLE cyl. Briggs engines (28-30 Series) check out this rebuild procedure it might prove helpful to ya ... Boo
http://outdoorpowerinfo.com/repairs/briggs_intek_single_ohv_nikki_carb.asp
Thank for all your input! I will check into it.
