- Nov 29, 2014
- Threads
- 64
- 24,718
Nope the Hex is just the cable crimp.
That is the 2nd JD with a welded on deck cable anchor plate so it looks like the factory may have made a modification.
Check the other end of the cable for an adjustment.
Also check the arm on the PTO lever.
It is held on with a single M6 high tensile bolt and they have been known to break or come loose then flog out the hole so the arm on the lever does not swing full distance so cable never moves full travel thus tension arm remains too slack to drive the belt.
Double check that the belt is actually on the pulleys properly by taking the covers off and then check the idler pulleys are bolted firmly to the deck & the bearings have not collapsed.
