jtlambrecht
- Jul 23, 2018
- 1
Hello All,
I've looked through some similar threads with this problem but none were specific to my engine. Symptoms: The motor will start just fine, but runs with constant surging. I can manipulate the choke some and get it to smooth out pretty good, or I can hold the governor arm in place and it will also run smoothly. I've had the entire motor out twice and opened it up to check the actual governor itself, and I can't see anything wrong with it. Timing is correct, cam gear is in proper position on the crank gear. It has a Nikki Model 697202 carb which I've also had apart and cleaned thoroughly. This lawn tractor belongs to my brother, and it sat outside, unused, for 7 or 8 years before he asked if I'd get it running. Most answers I've read on this similar problem were carb-related (i.e. cleaning, gaskets, seals, etc.) Has anyone ever had the governor itself actually fail? I am hoping to not tear the motor apart again, perhaps just a rebuild kit for the carb? Any advice would be appreciated, and also if anyone knows where I can purchase a rebuild kit for that Nikki carb. Would like to try that first.
