i have a Exmark Quest with a Kawasaki FR 651V engine, i was mowing and it just stopped. since trouble shooting i have done the following :
good clean gas--check
clean fuel lines --check
checked seat switch--check
checked compression and spark plugs--check
replaced carb--Check, installed new one same problem.
the mower will run off of carb cleaner as long as you keep spraying it in the carb.
any suggestions on where to look next? i read on one thread that someone else had this problem, what did you do to fix the issue.
