toro 4225 mower deck issue
The Rock
2011 toro 42 zero turn and the deck isn't level, I checked the hangers on the rear bar and they are level in the back but on the left side of the mower the deck is 3/4 inch lower. it looks like it needs a chain on that side. Any help or thoughts.. Thank You
If this manual does not help give us the model and serial numbers.
7394
I'm sure you have tire pressures up to spec, eh ?
Check that the bar the deck hangs on is in the bushing on both sides.
There was a problem with the popping out early on but I have not seen it on latter models so whatever was causing it to happen must have been fixed.
From memory it was the left side that usually popped out.
I remove both bushes, turn the rod diagonal between the rails refit the bushes then turn the bar square on the bolt up the bushes.
How the hell they do it is a mystery as there is stuff all clearence when it is all bolted back up and I really can not see a 3/4 thick rod flexing.
