JonnyBlaze
- May 6, 2017
- 338
Just picked up a Cub Cadet LTX1045 that doest run. Long story short, I removed valve cover and found the exhaust rocker arm was off the push rod. Pulled the rod out and it was straight. No damage. Put it back together. Tried adjusting both valves but its not firing up. I cleaned carb. New plug. New fuel filter. Sprayed starting fluid in carb and just get one single loud BOOM. I brought it to tdc on compression AND non compression when adjusting and still nothing. I dont FEEL compression when I put my finger over the spark plug hole.... Mower has 81 hours.
