Good idea, I will def keep that in mind. Thanks!:thumbsup:What I sometimes do is mow the whole lawn discharging, then cut the heavy areas again bagging but with the deck 1/4 to 1/2 inch higher. Just letting the clippings set out and dry for a little while makes a big difference and raising up a little gets most of the grass but cuts down on volume significantly.
I saw that platform and thought it looked interesting also, but I had written Toro off as it looked like they were a HomeDepot/Lowes carried product and I wanted an actual dealership for support. I think the Ferris dealer is also Toro now that I look at Toro website. The closer branch I went to did not have any Toro that I could see, but they are very small (400S was the only Ferris they had). The north store is the big location that is the warehouse.I still like the Liberty for you but if the ride quality won't work for you it's understandable. Do you have a Toro dealer? They have a machine with a suspended operator platform.
I am curious what has you recommend the Toro over the other ones I have looked at? Are you talking the Timecutter 48 or the Timecutter HD 48?
